Clear Config on 515E
Answered Question
Apr 24th, 2007
Hi all,
Clear Config as I understand it resets all configuration values of the 515E firewall.
Would there be anyway of retrieving cleared config information? Or is the config all contained within flash addresses which are overwritten with the default config by using rhe command?
thanks for your time
N.
Correct Answer by Collin Clark about 9 years 10 months ago
The config is actually stored in nvram. Once you clear it, its gone.
HTH and please rate.
Overall Rating: 4 (1 ratings)
Correct Answer
Collin Clark Tue, 04/24/2007 - 07:20
