20 gig line
Answered Question
Apr 24th, 2007
Question for you to connect to a 20 gig line, I'm assuming it is a gigaman, how is that usually done? Do we connect to via a gig port on a switch to the providers equipment which goes to the gigaman connection?
Correct Answer by Paolo Bevilacqua about 9 years 10 months ago
Yes.
As a courtesy to those providing answers, please rate useful posts using the scrollbox below!
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Tue, 04/24/2007 - 08:04
It is probably 2 x 10 GB circuits. Very expensive but a bit less today with the new generation of 10 GB switches.
Paolo Bevilacqua Tue, 04/24/2007 - 08:22
10 GB interfaces over fiber, there are various type of optical modules depending by the distance. Available on 3560E, 3750E, 4948, and of course the bigger switches.
wgranada1 Tue, 04/24/2007 - 08:26
I was trying to look does a 3845 series router support a 20 gigaman...so far I don't see anything yet
wgranada1 Tue, 04/24/2007 - 09:59
So to connect a 20 gigaman connection you would need a switch like a 3750E to connect
to the providers router correct with 2X10 gig uplinks?
Correct Answer
Paolo Bevilacqua Tue, 04/24/2007 - 10:42
Yes.
