CAD 7.0 installation problem
Apr 24th, 2007
I can't get past the "Disconnected from Directory Service, will try to reconnect" popup when trying to install CAD on the PG. Has anyone seen this before?
s-shishko Wed, 04/25/2007 - 07:49
Do you have private and public interfaces on PG? I saw such a problem while installing CAD on dual-nic machine (CAD 7.0.0)
thomas1 Wed, 04/25/2007 - 08:13
I think that may have been the bug that TAC referenced to me. I didn't get the specifics of the bug, but I was told to go to a newer version of CAD due to a known bug. I just placed the order this morning. I can see the private and public interface being a problem. If time permits, I may play with shutting down the private interfaces just to see if that makes a difference. I know that wouldn't be a "real" solution, but I'm just curious.
