Patrick Iseli Tue, 04/24/2007 - 09:51
  • Gold, 750 points or more
You change the objetct group.
But take care if the same object group is usesd in multiple ACLs then this will add or delete in all the ACLs.
Reference:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00800d641d.shtml
example:
(config)# object-group network host_grp_2
(config-network)# network-object host 172.16.10.1
(config-network)# network-object host 172.16.10.2
(config-network)# no network-object host 172.16.10.2
(config-network)# exit
sincerely
Patrick
Patrick Iseli Wed, 04/25/2007 - 06:13
Bu the way if you are doing < show access-list > you will see the expanded version of the access-list with the hitcounts.
