Not Recognized Voice Ports
Apr 24th, 2007
I purchased couple of 3640's, NM-2V and VIC-FXS cards.
I could not get the Voice cards recognized on the Routers (3640 with c3640-i-mz.122-11.T.bin)
Below is the output of "sh diag"
Slot 1:
Unknown (type 101) Port adapter
Port adapter is disabled
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 1.1 Board revision D0
Serial number 14706627 Part number 800-02491-02
FRU Part Number: NM-2V=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 65 01 01 00 E0 67 C3 50 09 BB 02 00 00 00 00
0x30: 68 00 00 00 99 06 16 17 FF FF FF FF FF FF FF FF
What might be the cause?
Thank you in advance,
Oguz Can
Overall Rating: 5 (2 ratings)
jreekers Tue, 04/24/2007 - 14:29
Hi Oguz,
You have to use an image on the 3640 that supports the ip plus feature set.
The image you're using:
only supports the IP feature set, as indicated in the filename "c3640-i...", an "ip plus" image will be named "c3640-is..."
Hope this helps, and please rate.
-Joe
oguzcan35 Wed, 04/25/2007 - 11:58
Hi Joe,
Thanks for your answer. I installed IP Plus image and it is resolved,
PS: I rated your answer.
Oguz Can
