WLC PSK
Apr 24th, 2007
So I have a 4402 and I have configured the WPA to use a Hex PSK using 64-bit. I type in 64 1's for example and click apply. When I go back into the WLAN it is set as ACSII not HEX. Any ideas? Is this a security feature?
diro Wed, 04/25/2007 - 10:26
  • Bronze, 100 points or more
This is normal behavior of the wlc
Amjad Abdullah Thu, 07/11/2013 - 00:18
  • Red, 2250 points or more
After you configure the key, you can not know what type of key (ASCII or HEX) is configured. It always shows "ASCII" on the GUI and on the CLI WLAN config it shows the security as PSK only. it does not state ASCII or HEX.
This is how the WLC behaves.
Amjad
Rating useful replies is more useful than saying "Thank you"
Trending Topics - Security & Network
