ip local policy weirdness
I have a policy enabled, and it works for ping and isakmp packets. It does not work for ESP packets. Is this a known issue?
I am looking to have crypto map configs working on 2 interfaces, with each having an internet connection. My ip local policy is to use PBR to have the reply traffic from the secondary connection go out that interface, versus the default route).
Overall Rating: 3 (1 ratings)
Richard Burts Tue, 04/24/2007 - 18:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Matt
I am not aware of an issue with this. I wonder if there is an order of operations aspect to be considered.
Perhaps you could share some details of the config?
Rick
interface GigabitEthernet0/0.1
description $FW_INSIDE$
encapsulation dot1Q 9
ip address x.y.z.1 255.255.255.252
ip access-group 103 in
ip nat inside
ip inspect XXXX in
ip virtual-reassembly
ip policy route-map mailmojo
interface GigabitEthernet0/1.1
description $FW_OUTSIDE$
encapsulation dot1Q 7
ip address a.b.c.d 255.255.255.248
ip access-group 105 in
ip nat outside
ip inspect XXXX out
no cdp enable
crypto map SDM_CMAP_1
route-map localPBR permit 10
match ip address acl_localPBR
set interface GigabitEthernet0/1.1
set ip default next-hop a.b.c.e
route-map mailmojo permit 10
match ip address 125
route-map mailmojo permit 20
match ip address secondaryVPN
sh access-list acl_localPBR
Extended IP access list acl_localPBR
5 permit esp host a.b.c.d any
10 permit ip host a.b.c.d any (1112 matches)
20 deny ip any any (432007 matches)
sh access-list 125
Extended IP access list 125
10 deny ip host 10.10.10.2 host 10.10.10.255 (3908 matches)
20 deny tcp host 10.10.10.2 any eq 135
30 permit ip host 10.10.10.2 any (7613579 matches)
sh access-list secondaryVPN
Extended IP access list secondaryVPN
10 permit ip x.y.t.0 0.0.0.255 192.168.6.0 0.0.0.255 (154756 matches)
20 permit ip x.y.r.0 0.0.0.255 192.168.6.0 0.0.0.255
30 permit ip x.y.s.0 0.0.0.255 192.168.6.0 0.0.0.255 (18 matches)
40 permit ip x.y.u.0 0.0.0.255 192.168.6.0 0.0.0.255 (3 matches)
50 deny ip any any (7057282 matches)
A.b.c.d is the IP address of the subint for the secondary ISP connection. A.b.c.e is the default gateway for that connection.
I have played with darn near every permuation of route-map commands to try to get this to work, but the ESP packets go out g0/1.2. I put 5 permit ESP.... in the list as a testing tool. I have g0/1 spanning to a box running wireshark, and I see the isakmp packets going to the right MAC addr, but not the ESP packets, even though the source/destination IP addresses are the same.
ACL 125 is to PBR some traffic for a statically natted service to an IP on the secondary ISP connection.
ACL seconaadryVPN is to PBR the traffic to the vpn ip pool out the g0/1.1 interface to which those vpn clients are connected.
