Get Phone by Pattern
Apr 24th, 2007
Hi someone know a way to get Phone by the pattern(Directory Number) via AXL? I just found listPhoneByDescription and listPhoneByName but doesn't work with pattern..
Sascha Monteiro Tue, 04/24/2007 - 23:47
I don't think you can, you can do a ListRoutePlanByType, not sure if that helps though.
Can you explain what you try to achive?
You could do a executeSQLQuery to retrieve the info you need.
