MPLS
Answered Question
Apr 24th, 2007
Hi.
The IOS IP BASE for 1841 support MPLS?
Correct Answer by mohammedmahmoud about 10 years 2 months ago
Hi there,
No the IP BASE (its an entry level IOS - simplest) won't supports MPLS, you have to get SP, Advanced Services, Enterprise Services or Advanced Enterprise Services.
Take a look at the attached diagram.
HTH, please rate if it does help,
Mohammed Mahmoud.
Overall Rating: 5 (1 ratings)
Correct Answer
mohammedmahmoud Tue, 04/24/2007 - 11:13
  • Green, 3000 points or more
Hi there,
Mohammed Mahmoud.
