WIC-1DSU-T1-V2 for Long Distance in MGCP Gateway
Answered Question
Apr 24th, 2007
I want to use a WIC-1DSU-T1-V2 to terminate a long distance T1 in an MGCP gateway. When I am setting the gateway up in CallManager, there is no option for this module. Which module should I choose?
Correct Answer by paolo bevilacqua about 10 years 3 months ago
You need another of the same module. Also VWIC2-xx-xx are now available and would provide same or better functionality.
You also need to check how many DSP do you have (do show diag to know), likely you have pvdm-16, that is not enough for 2 T1s, so you will need another PVDM-32 to be safe.
I suggest that you ask this long distance T1 to be provisioned as PRI as well so you will have all the features and ease of configuration and maintenance.
Hopes this helps, if so please rate post!
Overall Rating: 5 (1 ratings)
paolo bevilacqua Tue, 04/24/2007 - 11:19
  • Hall of Fame,
    Founding Member
Hi, that card is data only and cannot be used for voice. The module to use, depends on the router, what do you have ?
lhiatt Tue, 04/24/2007 - 11:20
It is a 2811. I am using a VWIC-1MFT-T1\E1 for the PRI
Correct Answer
paolo bevilacqua Tue, 04/24/2007 - 11:33
  • Hall of Fame,
    Founding Member
