User's greeting not playing we sent to voice mail
Apr 24th, 2007
I have a very strange problem. We have some users who prior to today had a Unity voice mail account with an Avaya phone and using PIMG. We cut them over to a Cisco phone today and when someone calls them from the PSTN they don't hear the users greeting, however I can see the call come in and connect and if I leave a message they will get it, now if an internal users calls (another IP Phone) they have no problem. I did change the switch to now point to Call Manager but stills does not work.
Any thoughts!
thisisshanky Tue, 04/24/2007 - 12:13
  • Purple, 4500 points or more
You may use Port status monitor to troubleshoot what Unity is doing when the call gets to Unity.
tony.hanson Tue, 04/24/2007 - 12:34
I went into Port status monitor and this is what it said:
State - Play Greeting
Call answered if needed
Playing greeting for Subscriber: Jane Doe
No DTMF received
Taking message for Subscriber: Jane Doe
Event is [RecordMsgEvent]
State - Record Message
Event is [HangupEvent]
Now If I leave a message right away she will get it, it's not playing her greeting message
eschulz Tue, 04/24/2007 - 12:58
  • Cisco Employee,
Sounds like maybe you are having a one-way audio problem between Unity and your gateway. Do you hear any audio from Unity during this call? (e.g. if you press # to end the recording you should hear after message menu options)
tony.hanson Tue, 04/24/2007 - 13:08
I do not hear anything from Unity even when I press the # key. The Unity server is at another location, but it worked with the same gateway prior to today. The only thing that's changed today is that we moved them from an Avaya phone to an IP phone. Now I didn't mention one thing, the customer still has the T1 Pri going through his Avaya system until we finish the other sites.
