04-24-2007 11:50 AM - edited 03-05-2019 03:39 PM
I have a gig port on a 7206 connected to carrier's fiber switch. we are seeing large amounts of output drops on that port. carrier says they do not see any drops on their equipment. it is connected at 100/full.
Total output drops: 242179
any help would be appreciated.
thx
04-24-2007 08:09 PM
Is the carrier connected on the ethernet port which comes up with the NPE ?
Or connecting onto any other additional PA card ?
can you also post the show interface ethernet x/x output as well as the config pertaining to ethernet interface..
regds
04-25-2007 06:25 AM
thanks for the reply. it is connected to the gig port on the NPE-G1.
here is the sho int:
GigabitEthernet0/3 is up, line protocol is up
Hardware is BCM1250 Internal MAC, address is 000f.3454.1819 (bia 000f.3454.1819)
Description: WillTel 100Mbps USO/100/HOUTX/HOUTX/GCGI/0243
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 5/255, rxload 1/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is autonegotiation, media type is SX
output flow-control is XON, input flow-control is XON
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 18:24:54
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 9405
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 6741000 bits/sec, 7194 packets/sec
5 minute output rate 21183000 bits/sec, 7314 packets/sec
151651409 packets input, 3833494550 bytes, 0 no buffer
Received 598 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 640604 multicast, 0 pause input
138927687 packets output, 2003255118 bytes, 0 underruns
0 lost carrier, 0 no carrier, 0 pause output
0 output buffer failures, 0 output buffers swapped ou
