Cisco Or Microsoft RDP + VPN
Apr 24th, 2007
I have encountered a very very perplexing problem. The Remote Client (4.8) VPN connection works great, I can icmp all hosts I need to, telnet etc BUT, when I RDP to the Terminal Server it connects and works fine, then you disconnect from that session and try to reconnect and can't, but the host is still active, can icmp it etc.
To reconnect you have to go into registry and delete the license key the terminal server issued and then you can reconnect. The said terminal server has no issues, but this does not happen if the server is only in remote admin mode and not a terminal server.
This is bizarre. Have you any thoughts?
Sincerely
