ASA - IPSEC and OSPF issue
Apr 24th, 2007
Hello!
We are using Cisco871 at branches and ASA5520 in router mode at central office. VPN3000 used to terminate IPSEC connections. I trying to implement backup links with OSPF and 'crypto map local-address' feature. Config at Cisco 871 looks like this:
interface Loopback1
ip address 172.16.255.10 255.255.255.255
crypto map VPN local-address Loopback1
crypto map VPN 10 ipsec-isakmp
set peer 10.1.5.1
set transform-set TRANSFORM_SET
match address VPN_TRIGGER
interface FastEthernet1
description MAIN LINK
ip address 172.16.1.10 255.255.255.0
crypto map VPN
interface FastEthernet2
description BACKUP LINK
ip address 172.16.2.10 255.255.255.0
crypto map VPN
router ospf 1
log-adjacency-changes
redistribute connected subnets
network 172.16.1.0 0.0.0.255 area 1.1.1.1
network 172.16.2.0 0.0.0.255 area 2.2.2.2
172.16.255.10 configured as peer adress for tunnel on VPN3000.
IPSEC tunnel works fine; 172.16.255.10 is accessible.
ciscoasa# sh route | b 172.16.255
O E2 172.16.255.10 255.255.255.255
[110/20] via 172.16.160.10, 0:04:26, link1
ciscoasa# sh conn detail | i 172.16.255.10
ESP dmz:10.1.5.1/41767 link1:172.16.255.10/56656
ESP dmz:10.1.5.1/4405 link1:172.16.255.10/38401
UDP dmz:10.1.5.1/500 link1:172.16.255.10/500 flags -
Lets shutdown one active link:
[110/20] via 172.16.0.27, 0:00:15, link2
172.16.255.10 now accessible via 'link2' interface, but UPD/500 connections is still bound to 'link1' interface..
Is it bug or feature? I suppose its feature. Is it possible to turn off that 'bind connection to interface' feature?
Maybe there are better solutions about backup links? For example, should I use some ISR to terminate OSPF on it (then 172.16.255.10 won't jump from one interface to another). Or, maybe, I should use two different IPSEC tunnels and run routing protocol inside them?
mchin345 Mon, 04/30/2007 - 11:28
  • Silver, 250 points or more
Check the ASA configuration especially VPN related config.
krasinform Tue, 05/01/2007 - 20:30
ASA isn't involved directly into VPN, its used as router and (statefull) firewall here. Problem is in the firewall states and dynamic routing.
