Amit Singh Wed, 04/25/2007 - 00:39
Srinivas,
1841 doesnot have a NM module so you cannot use the NM-CIDS, the hardware IDS/IPS module for the routers. You can go for atleast 2811 or higher to use the NM-CIDS module on ISR routers.
If you still want to stick with 1841, then you need to upgrade the router to atleast " Advanced Security " image to have the Cisco IOS IPS and firewall services work for you. Cisco IOS has a built in softeware IPS featureset on it.
Please find more details below:
http://www.cisco.com/en/US/products/ps6634/products_data_sheet0900aecd803137cf.html
HTH,Please rate if it does.
-amit singh
spremkumar Wed, 04/25/2007 - 00:39
Hi Srini
Cisco 1841 itself will support IDS feature but you need to have Advanced Security Feature set version of the ios installed in your router to have the same..
regds
