2821 rebooting
Apr 24th, 2007
  • Silver, 250 points or more
Dear All,
2821 routing is rebooting with the following message.
Intializing memory for ECC...
The above message is coming continuously instead of booting the router with IOS image (12.4 13a)
What could be the problem ?
I ahev formatted the flash and loaded new Image and removed all the modules from router , i rebooted the router but no luck...
Satish
spremkumar Wed, 04/25/2007 - 00:47
  • Red, 2250 points or more
Hi Satish
Can you try reseating your Memory Module and check ?
regds
smothuku Thu, 04/26/2007 - 20:08
Hi ,
Thanks for your reply.I already done it but no luck...I also changed the module and inserted in another memoru module...but no use..
Satish
royalblues Thu, 04/26/2007 - 23:24
  • Green, 3000 points or more
Better to raise an RMA with cisco if under a valid contract
Narayan
