reg:fxo to fxs config
Apr 25th, 2007
Dear experts,
Iam having 2610xm router and 2811 router in that having 2 port fxs and fxo cord in that routers.Now i connected back to back this router now iwant to configure fxo and fxs cord .how can i configure this fxs and fxo iwant to test voice through this back to back connection.plz help in this.
spremkumar Wed, 04/25/2007 - 01:00
Hi Srini
You need to connect the routers ethernet using cross cable once you have established the connected ethernet connectivity between the routers then you can try connecting the PSTN line on the FXO card and a dump Telephone equipment onto the FXS card.
By doing so when you call out the PSTN number connected on the FXO card of the router it should be configured in such a way that it forwards the same to the telephone equipment connected on the FXS card on the other router.
For more config info and scenario do refer this link..
