BGP/Serial line drop
tbarnett
A typical scenario 2621xm router with e1 link BGP running, How many hits would the cisco router need to have to take the BGP down or how long would the hits have to be .ie 200 ms ??
7 Replies 7
mohammedmahmoud
Level 11
Level 11
Hi there,
If you are talking about the BGP keepalive period then it is every 60 seconds by default.
HTH,
Mohammed Mahmoud.
Hi Mohmemmed
Its not actually the BGP keepalive period, its how long would a hit on the serial link have to be for the router to take the link down
Hi Terry,
I think that this depends in the interface keepalives period (10 seconds by default), kindly use this link to troubleshoot serial lines problems:
http://www.cisco.com/univercd/cc/td/doc/cisintwk/itg_v1/tr1915.htm
HTH,
Mohammed Mahmoud.
Mohammed
I think we are getting mixed up with the actual information i require.
Basically i am trying to distinguish if a local tail cct is taking hits, and they are <=50ms would a cisco router determined these as a drop , if not, what is that actual time in ms that a cisco router will recognise as a hit ?
Hi there,
Sorry for misunderstanding your question, i'll trying to figure it out for you.
BR,
Mohammed Mahmoud.
Tks Mohammed
I just need to recognise what the default value is that the interface will be declared down due to a hit
tbarnett
Hi i know how to actually troubleshoot serial links , its how many times a router requires to see a hit before it will take it down?
