Shipping box content
Answered Question
Apr 25th, 2007
Is there a method to find out the packing content of shipping box? For example “Catalyst 3750-E Switch Getting Started Guide” claim the AC power cable is enclosed, but there is no information about TwinGig Converter Module. Cisco Dynamic Configuration Tool (guest version) asks to select Power Cable, but show the TwinGig is included.
I mentioned 3750-E as example, but is there a general rule?
Correct Answer by ankbhasi about 10 years 3 months ago
Hi Friend,
I found out that it should come with the box only if you select that part at the time of ordering. If you have not selected that TwinGig at the time of ordering then it will not be shipped.
So you may contact your sales partner and may ask what can be done now to get if possible.
Ankur
*Pls rate all helpfull post
Overall Rating: 5 (1 ratings)
ankbhasi Wed, 04/25/2007 - 04:27
  • Cisco Employee,
Hi Friend,
Yes you can find the shipping contents of any switches.
Open this link
http://www.cisco.com/univercd
Then from CATALYST SWITCH section dropdown select any switch and click on any release and then select HARDWARE INSTALLATION GUIDE.
One done the click on SWITCH INSTALLATION link and serach for "Verifying Package Contents" and it will give you all the contents which are shipped with the box.
Ankur
pavelalex1 Wed, 04/25/2007 - 05:05
For 3750E it is named "Box Content" where is mentioned: "The box contents are described in the switch getting started guide. If any item is missing or damaged, contact your Cisco representative or reseller for support"
"Getting started guide" lists next contents:
1 Catalyst 3750E-48 Power over Ethernet (PoE) switch
2 Documentation
3 AC power cord
4 Console cable
5 StackWise cable, 0.5-meter
6 Two 19-inch mounting brackets
7 Cable guide
8 Four rubber mounting feet
9 Power cord retainer
10 Four number-12 Phillips machine screws
11 Twelve number-8 Phillips flat-head screws
12 One black Phillips machine screw
13 Ground lug screw and ring terminal
There is no information about TwinGig converter, but Configuration Tools insist it's included.
ankbhasi Wed, 04/25/2007 - 08:22
  • Cisco Employee,
Hi Friend,
AFAIK it is not shipped with the box and you have to purchase in spare but I will double check tomorrow and update you.
Ankur
Correct Answer
ankbhasi Fri, 04/27/2007 - 00:59
  • Cisco Employee,
Hi Friend,
Ankur
