limiting bandwith on a cat 2960
rabeder
hi,
i have a 2960 switch, on whic i have to limit the bandwith on port fa0/25 to 100kb/s.
i tried the command "srr-queue bandwith limit 10" and defined "bandw 1000" on the fa0/24.
so 10% of 1000kb/s is 100kb/s - but there was no effekt
any idea ?
leighharrison
Level 7
Level 7
Hi there,
It seems that you might be missing the magic keyword "mls qos" in global config mode.
This then tells the switch to read the qos commands on the interfaces.
Then try popping in the command "show mls qos interface f0/25 queue" and see if it's doing the business.
Let me know how it goes!
LH
** Please rate all posts **
hi out there and thank you for your answer,
i configured the mls qos in global config.
here is the konfig - i am talking about fa0/24
- it should throttle down the traffic to 100kb/s
any idea
switch_zentrale#sh run
Building configuration...
Current configuration : 2065 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname switch_zentrale
no aaa new-model
ip subnet-zero
mls qos srr-queue output cos-map queue 1 threshold 1 6 7
mls qos
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
policy-map 20mega
class class-default
police 20000000 100000 exceed-action drop
policy-map 5mega
class class-default
police 5000000 10000 exceed-action drop
interface FastEthernet0/1
switchport mode trunk
no logging event link-status
srr-queue bandwidth limit 50
mls qos trust dscp
spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 3
switchport mode access
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
switchport trunk allowed vlan 1-3,10,1002-1005
bandwidth 1000
load-interval 30
srr-queue bandwidth share 2 3 3 2
srr-queue bandwidth limit 10
priority-queue out
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 1.1.1.1 255.255.255.0
no ip route-cache
ip http server
control-plane
line con 0
line vty 0 4
no login
line vty 5 15
no login
monitor session 1 source interface Fa0/24
monitor session 1 destination interface Fa0/3
end
switch_zentrale#show mls qos interface f0/24 queue
FastEthernet0/24
Egress Priority Queue : enabled
Shaped queue weights (absolute) : 25 0 0 0
Shared queue weights : 2 3 3 2
The port bandwidth limit : 10
The port is mapped to qset : 1
switch_zentrale#sh int fa0/24
FastEthernet0/24 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0018.b931.8b9a (bia 0018.b931.8b9a)
MTU 1500 bytes, BW 1000 Kbit, DLY 1000 usec,
reliability 255/255, txload 82/255, rxload 82/255
Keepalive set (10 sec)
Half-duplex, 10Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:07, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 323000 bits/sec, 331 packets/sec
30 second output rate 324000 bits/sec, 333 packets/sec
268068 packets input, 32671441 bytes, 0 no buffer
Received 1033 broadcasts (0 multicast)
0 watchdog, 205 multicast, 0 pause input
274864 packets output, 33136266 bytes, 0 underruns
