Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1927448members
1240167discussions
Community Activity
Problems with SNMP on the ASA 5555-X
Hello everyone,I have a CISCO ASA 5555-X configured in multi-context mode and I want to monitor it via SNMP.However, I can't find the MIB files for this device.How can I get them?I don't have access to ftp://ftp.cisco.com/pub/mibs/supportlists/asa/as...
vsmjoao14 by Level 1
  • 57 Views
  • 1 replies
EEM scripting help
I'm trying to have EEM script where I run the script manually and it display the output of the results in the session but for some reason I'm unable to do so. This is what I have so far(config)#event manager applet TestCommand(config-applet)# event n...
Sunny5 by Level 1
  • 50 Views
  • 1 replies
Setting UP a SECOND ASA5506-x firewall
Hello, I successfully set up/configured my first ASA device. I just purchased as second 5506 and am wondering about how compatible or incompatible the bkup configuration files I’ve saved from the first device are gonna be with the second ASA. It ment...
Cisco Catalyst Center に登録した機器にて "CRL fetch failed" が出力される
Cisco Catalyst Center に登録した機器にて、下記のエラーメッセージが 5 秒おきに出力される場合があります。 %PKI-3-CRL_FETCH_FAIL: CRL fetch for trustpoint DNAC-CA failed Reason : Enrollment URL not configured.      通常、内部認証局 (CA-Certification Authority) によって発行された証明書には...
xxin2 by Cisco Employee
  • 24 Views
  • 0 replies
CSSM 上で製品インスタンスが正常に生成されない事象の対応方法
Smart Licensing Using Policy の offline mode を利用の場合、Cisco Smart Software Manager (CSSM) へ RUM レポートをアップロードした後、スタック構成のメンバーに製品インスタンスが正常に生成されない場合があります。 その時、トラストファイルを生成してからライセンスの再登録で事象が改善できるかをご確認ください。   ====手順ここから==== 1. まず対象機器にてライセンス情報をクリアしてから、機器を再起動してく...
  • 19 Views
  • 0 replies
Wired Guest issues in foreign-acnhor setup
Wired guests are not able to get out to internet, they can ping only at when payload is set to 1300 bytes or lower, this seems like an MTU issue, but its only effecting wired guest not wireless guest. Setup is a 9800 foreign on 17.9.5 code and 5520 a...
ammahend by VIP
  • 92 Views
  • 3 replies
AP-AIR2802i-B-K9 No join
l installed newest version of Wireless controller 9800-CL Cloud but wont Join DTLS Error l dont why it wont join to controller
lisavbedt by Level 1
  • 141 Views
  • 9 replies
Get report status endpoint from ISE
Dear Community,There have 2 kind different of AnyConnect agent version on ISE.Also have 2 kind of Complain Module as well.Please share how to get the report from ISE with below points.how to get the report status of endpoint with new version and old ...
Da ICS16 by Level 1
  • 23 Views
  • 0 replies
Can I change the regulatory domain for our new CW9164I-ROW AP?
We have a 9800-CL Wireless Controller running 17.12.2.  We just got a new CW9164I-ROW AP and its registered by the operational interfaces are down due to a regulatory domain error.  Is there a way to change the regulatory domain for the access point?...
9200 switch loosing its configuration
Hi guys, One of my friend is facing a issue and it seems quite weird.2 of his 9200 switches lost their configuration even though configuration was saved and even if for some reason switch restarted but they should not  loose its configuration. what c...
Cisco Packet Tracer 2960-24TT indicates Orange (amber)
Hello everyone. I work in Cisco Packet Tracer and have a simple network with 5 subnetworks connected through 2960-24TT Switch. The problem is when i connect 5 subnetworks to 1 network some (3) routes light orange (amber). And i can`t fix it. Where sh...
