Changing LAN IP via SDM in a 800 series
Apr 25th, 2007
Hi all,
my 857W doesn't like me. I can do whatever I want it will not accept the LAN IP I have entered in the SDM setup. It says its preparing coammnds for delivery and after ~2 minutes it loses connection to the router. But when I restart the SDM and use the new LAN IP the router does not answer. It either answers with the old one. What kind of feature is this ? My other less "advanced" routers where defenitely more intuitive than this one.
The requested username&password change for the first setup lets also "hang" the the SDM, but after a SDM restart it works again and it even changed username& pw. But the LAN IP . . . :-( Guess this SMD interface is still a bit beta !? Or is my router defective ?
Joe
spremkumar Wed, 04/25/2007 - 03:56
Hi Joe
May be just to fix this why cant you try using the console access ?
regds
