I am Facing the Problem with RisPort Webservice to get IP phone information
Hi ALL,
I am facing the problem with RisPort webservice to get the Device Information(like DevicelistX in CCM 4.0) but iam getting the Errors, is there anybody knows how to get the device information from the CCM 5.0 please help me out , its a critical Issue for me
Thaks in advanced
Instructions: I have to use HTTPS protocol
bjpaddock Wed, 04/25/2007 - 08:31
At a quick glance, it looks to me like you do not have a valid certificate for your call manager
bjpaddock Thu, 04/26/2007 - 00:37
Ravindra,
You will find the code you need to avoid the need for certificates in the AXL toolkit provided by Cisco, it just needs tweaking to send messages to the RisPort. You will find it on your Call Manager at
https://ccmserver:8443/plugins/axlsqltoolkit.zip
If you have read the rest of this forum you will see I have not yet correctly got a running RisPort program!
Ben
Hi Ben,
Thanks for your reply
as per my knowledge,axltoolkit.zip application is different from RisPort Webservice.
I already used that axltoolkit and AXL API(like java API)for interacting with CCM 5.0, every thing is working fine but here to get the device information(like DevicelistX in CCM 4.0) iam not using that iam directly accessing from the webservice.In AXL API also doesn't have any method to get all device information from CCM 5.0 so based on that document CCM 5.0 Developer Guide.pdf(https://serverName:8443/realtimeservice/services/RisPort?wsdl ) iam getting the WSDL file from that site and then iam trying to access using sample application
Ravindra
