CCIE BOSON exam sim
Answered Question
Apr 25th, 2007
hello,
I want to know that is that Boson exam sims are helpfull in exam preperation?
what are the main useful features of boson exam sim? Is that only questions and answers only or its also include the explanations of topics?
Correct Answer by royalblues about 9 years 8 months ago
I use 3725 most often and use ram as 160 and evrything works fine..
Never decompressed the image also
check the mail i sent
Narayan
Correct Answer by mounir.mohamed about 9 years 8 months ago
Dear Devang,
you can decompressing the IOS image on unix/linux by using this command "[email protected]$ unzip -p c3640-js-mz.124-10a.bin > c3640-js-mz.124-10a.image"
Also you decompressing the IOS image on windows systems by using WINRAR, Open WINRAR program then selecte the IOS image, then click one the image tiwce, then extract the file with .BIN exe some where, then to to such place and rename the .BIN file to be .image.
Regarding the above error, just decompressing the IOS image and make sure the RAM you located for the router is big enough (you can cehck the RAM needed for one IOS image by www.cisco.com/go/fn)
Plase rate helpful posts.
Best Regards,
Mounir Mohamed
Dear All,
It's very simple by it's just steps if any missing the sim report such errors:
Here is a breif about how to use it:
1-Install Wincap / then install dynagen
2-for window users dynagem files will located in the below path (C:\Program Files\Dynamips\sample_labs) also there is a very usful file in such path called "all_config_options.txt" try to open this file by internet explorer to know how to use different router series and how to connect interfaces for each type of router
3-place all your IOS images in one place to refear to next time in the configuration file (.Net file)
4-open a new text file and place your topology configurations there then replace the file ext by .net (topology.txt --> topology.net) make sure the widnows not hidden files ex.
5-Let create asmile topology with 3 3725 routers + 1 Switch and 1 Frame-relay switch
Here is the config:
autostart = false
[localhost]
#Define router platforms#
#specify router RAM- Take care of running IOS#
ram = 128
#Specifiy the your image path followed by image name#
image = c:\images\c3725-ipbase-mz.123-9b.image
#here i will add network module with 4 serials in slot1#
slot1 = NM-4T
#Another series of routers#
ram = 96
slot0 = NM-16ESW
image = c:\images\c3640-js-mz.124-10a.image
#Creat routers insteance#
model = 3725
F0/0 = sw1 f0/1
S1/0 = FR1 1
model = 3725
F0/0 = sw1 f0/2
S1/0 = FR1 2
model = 3725
f0/0 = sw1 f0/3
s1/0 = FR1 3
#Create switch insteance#
model = 3640
#Create Frame-relay switch and connect DLCI's#
1:102 = 2:201
1:103 = 3:301
If somene can not understand me the below forum has experts more than me :)
http://7200emu.hacki.at/
Please rate helpful posts.
Best Regards,
Mounir Mohamed
Overall Rating: 4.9 (25 ratings)
mounir.mohamed Wed, 04/25/2007 - 07:25
Dear,
there is an perfect simulator specially for CCIE lab practic, it's only run 2600, 2600, 3700, 7200, but also you can solve the switching issue by using 3600 with NM-16E interface which provide you with 16 switchport supporintg trunking and alot of switching stuff.
Check and download the software from the below URL and feel free to ask me about any config related to such sim, as i'm alredady use it for my lab preparation.
http://www.ipflow.utc.fr/index.php/Cisco_7200_Simulator
Please Rate helpful posts.
Best Regards,
Mounir Mohamed
royalblues Thu, 04/26/2007 - 08:09
Hey Dewang,
Nice to see back in Netpro.
The dynamips simulator is by far the best simulator i have experienced.
I have simulated quite a few topologies with it. Let me know if you need any .net files for the simulation and i will be happy to share them..
Mounir, would you be able to share any .net files simualting the NM-16EW. I have never been able to successfully simulate it
Narayan
devang_etcom Thu, 04/26/2007 - 09:37
Hi Narayan,
hey actually i dont know how to use it so will you please provide me the detail for installation as well as how to use it information so i can install it... i do have VISTA in my laptop... so it will be good if you provide the link or step by step procedure for installation...
I tried to run simulator but now its giving error like unable to create loc file" c7200_i0_lock
then unable to create VM instance and unable to create instance... so please do needful for the same...
regards
Devang
Chandramohan Na... Thu, 04/26/2007 - 10:55
I just downloaded and installed it. Then I also downloaded the Cisco IOS image files for 7200 and 3640 in to the same folder. And the I created two batch files as follows:
7200.bat:
dynamips-wxp -t npe-400 -p 1:PA-A1 -p 2:PA-8T -p 3:PA-4E -p 4:PA-POS-OC3 -p 6:PA-FE-TX -P 7200 c7200-spservicesk9-mz.124-11.T1.bin
3600.bat:
dynamips-wxp -p 1:NM-1E -p 2:NM-4E -p 3:NM-1FE-TX -p 4:NM-4T -P 3600 c3640-ik9o3s-mz.124-13b.bin
Works great.....
Correct Answer
mounir.mohamed Thu, 04/26/2007 - 11:42
Dear All,
Here is the config:
autostart = false
[localhost]
ram = 128
slot1 = NM-4T
ram = 96
slot0 = NM-16ESW
model = 3725
F0/0 = sw1 f0/1
S1/0 = FR1 1
model = 3725
F0/0 = sw1 f0/2
S1/0 = FR1 2
model = 3725
f0/0 = sw1 f0/3
s1/0 = FR1 3
model = 3640
1:102 = 2:201
1:103 = 3:301
Best Regards,
Mounir Mohamed
mounir.mohamed Thu, 04/26/2007 - 10:53
Dear Nrayan,
With pleasure
here is a smiple file that created by myself, and use it for my CCIE LAB prep.
In the below configurations, i'm using 2 routers (3725) and one 3640 instead of 3350 switch.
autostart = false
[localhost]
ram = 128
image = c:\images\c3725-adventerprisek9-mz.124-13a.image
slot1 = NM-4T
ram = 128
slot0 = NM-16ESW
idlepc = 0x60a614b8
model = 3725
F0/0 = sw1 f0/1
S1/0 = FR1 1
idlepc = 0x60a60808
model = 3725
F0/0 = sw1 f0/2
S1/0 = FR1 2
model = 3640
idlepc = 0x60423bf8
Feel free to contact me about configurations like that, i like to play with such stuff.
Best Regards,
Mounir Mohamed
devang_etcom Thu, 04/26/2007 - 13:13
mounir,
if its possible then will you please show me how to create the connectivity... i means how to connect the router virtualy with each other like topology diagram... will you please explain it in more detail... as well as how many routers and switches i can use for the same...
regards
Devang
mounir.mohamed Thu, 04/26/2007 - 15:45
Dear devang_etcom,
Sure, make sure that you already configured the main platforms and interfaces
ram = 128
slot1 = NM-4T
ram = 128
slot0 = NM-16ESW
Router connections:
Well in the below config file we will connected R1 with R2 Direct Fastethernet interface
model = 3725
F0/0 = R2 f0/0
model = 3725
In the second below example we will connected R1 and R2 using Serial interfaces.
model = 3725
S1/0 = R2 S1/1
model = 3725
In the 3rd below example we will connect R1 with R2 by Fastethernet interfaces over SW1.
model = 3725
F0/0 = sw1 f0/1
model = 3725
F0/0 = sw1 f0/2
model = 3640
In the last example we will connect R1 and R2 over Frame-relay switch, R1 will be connected to FRSW on port 1 using DLCI 102 and R2 connected to the FRSW on port 2 using dlci 201
model = 3725
S1/0 = FR1 1
model = 3725
S1/0 = FR1 2
1:102 = 2:201
Best Regards,
Mounir Mohamed
royalblues Thu, 04/26/2007 - 22:39
Thanks Mounir,
That helped. Will surely try it out this weekend
Narayan
devang_etcom Sat, 04/28/2007 - 03:12
Narayan and Munir...
I am getting this messgae on my screen at very higher repitation rate...
here is the messages:
y_lo0 ($ 2) = 0x0000000000000000 entry_lo1 ($ 3) = 0x0000000000000000
context ($ 4) = 0x0000000000000000 pagemask ($ 5) = 0x0000000000000000
wired ($ 6) = 0x0000000000000000 info ($ 7) = 0x0000000020000000
badvaddr ($ 8) = 0x00000000644a5440 count ($ 9) = 0xffffffff93e84964
entry_hi ($10) = 0x0000000000000000 compare ($11) = 0x00000000611bf534
status ($12) = 0x0000000000408101 cause ($13) = 0x0000000000008008
epc ($14) = 0xffffffff806456ec prid ($15) = 0x0000000000002721
config ($16) = 0x0000000000c08ff0 ll_addr ($17) = 0x0000000000000000
watch_lo ($18) = 0x0000000000000000 watch_hi ($19) = 0x0000000000000000
xcontext ($20) = 0x0000000000000000 cp0_r21 ($21) = 0x0000000000000000
cp0_r22 ($22) = 0x0000000000000000 cp0_r23 ($23) = 0x0000000000000000
cp0_r24 ($24) = 0x0000000000000000 cp0_r25 ($25) = 0x0000000000000000
ecc ($26) = 0x0000000000000000 cache_err ($27) = 0x0000000000000000
tag_lo ($28) = 0x0000000000000000 tag_hi ($29) = 0x0000000000000000
err_epc ($30) = 0x0000000000000000 cp0_r31 ($31) = 0x0000000000000000
IRQ count: 11343, IRQ false positives: 9821, IRQ Pending: 1
Timer IRQ count: 11341, pending: 1123, timer drift: 28
i am not decompressing the IOS ... so how can we do the decompression... is that the simple processs as unzip...
i am getting this messages on both window and linux... both....
is there any one who had same issue and any trick to resolve this...
regards
Devang
Correct Answer
mounir.mohamed Sat, 04/28/2007 - 03:31
Dear Devang,
Best Regards,
Mounir Mohamed
Correct Answer
royalblues Sat, 04/28/2007 - 04:12
Narayan
mounir.mohamed Sat, 04/28/2007 - 23:55
Dear royalblues,
beleive me it will give you great and different Throughput if you decompressed the image, i was running 3 routers maximum on my laptop (withou decompressed the image)but after decompressed the IOS image and use the idlepc values i got 6/7 routers per time, so just try to test it.
I didn't receive any mail from you!!
Best Regards,
Mounir Mohamed
royalblues Sun, 04/29/2007 - 03:20
Hi Mounir,
Will try decompressing the image.. i just received a new laptop with dual core so i am able to simulate around 6 easily..:-)
I had actually sent a detailed mail to devang on how to create a .net file and was referring to that.
Can i have your mail address btw?
Narayan
mounir.mohamed Sun, 04/29/2007 - 03:31
Guys,
The just spend 5 minutes to read the attached file, then i promise u will never need to ask anybody about dynagen, U will be asked :)
Note: Open the file with Internet explorer or firefox for a good view.
Best Regards,
Mounir Mohamed
devang_etcom Sat, 04/28/2007 - 12:27
thanks mounir and narayan...
i just decompress IOS and it works...
now trying to make some .net file
so now .net file i have to put it in the sample lab folder... right!!!
thanks again...
regards
Devang
devang_etcom Sat, 04/28/2007 - 20:35
but how to create that .net file...
let say if i will create my own topology and i want to run that topology then how can i make it executable... normally we create our topology in notepad and then save it... so do i need to change that .txt extension to .net...
regards
Devang
mohammedmahmoud Sat, 04/28/2007 - 22:42
Hi Devnag,
Yes it is just that simple, create it via notepad and rename it to .net and just double click it after loading the dynamips service.
HTH,
Mohammed Mahmoud.
royalblues Sun, 04/29/2007 - 03:25
Devang,
Will send out some .net files to you.
But make sure you change the image name to the one stored localy :-)
Narayan
devang_etcom Sun, 04/29/2007 - 21:06
hi...
now in vista... when i telnet to R1 then nothing is displayed in screen after the messgae connected to R...
and on linux its always gives me message of server is shutting down...
man i get tired of it... any alternative solution....
regards
Devang
royalblues Sun, 04/29/2007 - 22:41
I have never tried it in Vista.
Will it be possible to test it in WIN2K3 or WINXP. I never faced problem with these 2 operating systems
Narayan
mounir.mohamed Sun, 04/29/2007 - 23:13
Regarding the server shutdown issue, Make sure that you dynamips server, the second issue usually happen due to low memory assigned to the router instance (memory lower than the IOS needs) or lack of PC memory which is solved by decompressing the image.
Best Regards,
Mounir Mohamed
ipengineer Mon, 04/30/2007 - 04:44
Hi Munir,
Wonderful tutorials, but Cisco 3700 not supported!! any advice.
Podem Klark.
mounir.mohamed Mon, 04/30/2007 - 04:48
Dear Padem,
Make sure that your dynagen/dynamips verions is dynagen-0.9.0_dynamips-0.2.7-RC1_Win_XP_setup.exe.
Best Regards,
Mounir Mohamed
ipengineer Mon, 04/30/2007 - 04:57
NO am running version 25!! so ithink my verion spoiled but the version you advised not available on dynagen official website
devang_etcom Mon, 04/30/2007 - 06:26
narayan...
what is your cpu specification and what is your RAM size... in your laptop/desktop...
royalblues Mon, 04/30/2007 - 06:44
Yes
Intel centrino Duo
1 GB RAM
80 GB HDD
Running windows XP SP2
Narayan
devang_etcom Mon, 04/30/2007 - 07:27
i have 512 ram and running vista so i think this is because of low memory i am facing all the issue...
royalblues Mon, 04/30/2007 - 07:51
RAM should not be a problem as i used to run it on 512K before.
But i had never tried on Vista...
If possible try in on WINXP. it works like a charm and never faced in a
Narayan
