Point to Point
Apr 25th, 2007
We are looking to get a point to point from "office a" to "office b" with a T1 line. We have several spare cisco 1721 routers and wanted to see if we could use those to connect the two offices? I am not sure if we will be able to use a 1721 to terminate? Does anyone have any helpful information on configuring a PPP over ethernet between two offices using cisco 1721 routers?
Overall Rating: 5 (4 ratings)
mounir.mohamed Wed, 04/25/2007 - 05:30
Dear phusion36,
I can not understand ur question 100%, you said you gone use T1 between to sites, is such T1 will be leased line or through ISP? also why do u need PPP over ethernet config?
Please rate helpful posts
Best Regards,
Mounir Mohamed
phusion36 Wed, 04/25/2007 - 05:36
The person who does our router configurations is unfortunately in the hospital at the current time and unavailable to us so sorry if I am not asking hte right questions. I am just trying to see if we are going to need to by any additional equipment and see what we would need to do moving forward. With that said we had ordered a point to point from XO and will be paying monthly for that connection between the two offices. There will be no Internet connected to the line, just a way for the two offices to have a pipe to transfer large files daily. They will be transferring scanned in documents from "office b" to "office a". We have quite a few docs to scan at that location and the comapny we are using for the document scanning said we needed a PPP to connect the offices. So in short we are looking to see if the cisco 1721 routers will allow us to connect the two offices over the PPP and what else we may need to connect the two offices and of course configure the router. I have a little bit of experiance (very little) configuring the 1721's for a simple t1 line, but never have interconnected offices. The routers we have all have WIC DSU T1 cards in them. Just looking for some direction, I appreciate any help. Thank you.
mounir.mohamed Wed, 04/25/2007 - 06:01
Dear ,
First of all if you need full information about your Cisco 1721 router you can use the below URL anytime:
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a00800920ec.html
Regarding the T1 PPP confgiurations, the below line will show you how to config the T1 interface for PPP on both side (Branches) but please take care about the timesolts/framing/coding you have to check with your telco company about your timesolts, and the Framing/conding supported
Interface serial 0/0
service-module t1 clock source internal
service-module t1 timeslots 1-24 speed 64
service-module t1 framing esf
service-module t1 linecode b8zs
ip address 1.1.1.1 255.255.255.0
encapsulation ppp
fair-que
no shut
Please Rate helpful posts.
Best Regards,
Mounir Mohamed
phusion36 Thu, 04/26/2007 - 12:12
would I be able to perform this in a bridge mode? Also is it possible at all to find a way to upgrade IOS as I am on an older version of 12.2 and it seems next to impossible to do that. Here is what I was have been getting help with so far, just not sure how to proceed from here as to whether I need to configure the FastEthernet0 with the IPs or how to proceed from there:
Site 1:
bridge 1 protocol ieee
interface Serial0
encapsulation ppp
service-module t1 clock source line
bridge-group 1
no shut
int FastEthernet0
bridge-group 1
no shut
Site 2:
interface Serial0
encapsulation ppp
bridge-group 1
no shut
interface FastEthernet0
bridge-group 1
no shut
