Problem with IOS
Apr 25th, 2007
I'm having problems with IOS file (1700 series router), when i try boot the router with the new IOS appear this error:
*** System received a Software forced crash ***
signal= 0x17, code= 0x5, context= 0x0
PC = 0xbaddaddd, Vector = 0xbaddaddd, SP = 0xbaddaddd
how can i solv this?
o.wong Thu, 04/26/2007 - 02:28
This KB article should point you in the right direction:
http://www.ciscotaccc.com/kaidara-advisor/core/showcase?case=K48918452
You said that you had tried loading a new IOS - I assume the router was working well before, so the most likely cause of this error is corrupt IOS image.
You can try downloading a new IOS image from Cisco.com. You will probably have to load this new IOS from ROMMON mode on the router. Please refer here for a how-to:
http://www.cisco.com/en/US/partner/products/hw/routers/ps221/products_tech_note09186a00800942dc.shtml
Hope this helps.
Oliver
