Cisco VPN Client Sateful Firewall and Exchange
Apr 25th, 2007
Has anyone else run into the issue where if the Client stateful firewall is checked, messages hang in the Outbox of the Exchange client?
Below is the log:
29 10:07:36.957 04/25/07 Sev=Info/4 FIREWALL/0x63A00003
BLOCK: UDP <EXCH IP>:37255 to <PC IP>:1163
amritpatek Wed, 05/02/2007 - 05:22
  • Silver, 250 points or more
Check if following is configured. Under the Configuration | User Management | Base Group | Client FW Parameters Tab choose
'Firewall Required', then select Cisco Integrated Client Firewall. You would then specify the filter you want to use for the client. This uses the Policy Pushed(CPP)feature. Following link may help you
http://www.cisco.com/univercd/cc/td/doc/product/vpn/client/rel4_0/admin_gd/vcach1.htm#1151504
