router dead process
Apr 25th, 2007
we have a router cisco 3825.
the router has 256 mb of memory, but it is not using all of it because of dead process which is called "usb_startup" this dead process takes something like 60mb of the router memory. the reload command doesnt solve the problem.
how can we solve the probelm?
thank you
paolo bevilacqua Wed, 04/25/2007 - 07:01
  • Hall of Fame,
    Founding Member
please post output of "show version" and "show process memory ", where is the PID of "usb_startup", first number on the left.
Also, do you have any error message leading you to believe the router is out of memory ?
kfirharel Wed, 04/25/2007 - 07:15
here is the show ver
Cisco IOS Software, 3800 Software (C3825-SPSERVICESK9-M), Version 12.4(6)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Thu 23-Feb-06 01:02 by ccai
ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
tira_barak uptime is 7 hours, 45 minutes
System returned to ROM by reload at 07:39:49 UTC Wed Apr 25 2007
System image file is "flash:c3825-spservicesk9-mz.124-6.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 3825 (revision 1.1) with 227328K/34816K bytes of memory.
Processor board ID FTX1020A5L4
2 Gigabit Ethernet interfaces
1 Serial(sync/async) interface
1 ISDN Basic Rate interface
1 Channelized (E1 or T1)/PRI port
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
here is the show memory dead
66481400 0000000028 664813A4 6648144C 001 -------- -------- 60E34604 USB Startup
6648144C 0000000028 66481400 66481498 001 -------- -------- 60E34604 USB Startup
66481498 0000000072 6648144C 66481510 001 -------- -------- 60E34604 USB Startup
66481510 0000000028 66481498 6648155C 001 -------- -------- 60E34604 USB Startup
6648155C 0000000028 66481510 664815A8 001 -------- -------- 60E34604 USB Startup
664815A8 0000000132 6648155C 6648165C 001 -------- -------- 60E34604 USB Startup
6648165C 0000000052 664815A8 664816C0 001 -------- -------- 60E33654 USB Startup
Address Bytes Prev Next Ref PrevF NextF Alloc PC what
664816C0 0000000040 6648165C 66481718 001 -------- -------- 60E32F08 USB Startup
66481718 0000000028 664816C0 66481764 001 -------- -------- 60E32F90 USB Startup
66481764 0000000028 66481718 664817B0 001 -------- -------- 60E33690 USB Startup
664817B0 0000000028 66481764 664817FC 001 -------- -------- 60E328CC USB Startup
664817FC 0000000036 664817B0 66481850 001 -------- -------- 60E32F90 USB Startup
66481850 0000004404 664817FC 664829B4 001 -------- -------- 60E3290C USB Startup
664829B4 0000000040 66481850 66482A0C 001 -------- -------- 60E32F08 USB Startup
lots and lots of the message above
the "usb_startup" is only seen on the show memory dead command.
here is a capture of the show memomry, you can see that the sum of process and i/o is not even close to 256 mb.
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 65894CE0 139899680 139019004 880676 621840 681444
I/O 2DE00000 35651072 10723912 24927160 24913248 24910524
when i use the show process memory command you can see that dead process is using 60mb
PID TTY Allocated Freed Holding Getbufs Retbufs Process
0 0 43250752 15201800 25081704 614 91 *Init*
0 0 12148 340452 12148 0 0 *Sched*
0 0 812064 939656 668216 12 12 *Dead*
1 0 5052 0 12096 0 0 Chunk Manager
2 0 252 252 4044 0 0 Load Meter
paolo bevilacqua Wed, 04/25/2007 - 07:46
  • Hall of Fame,
    Founding Member
