router dead process
Apr 25th, 2007
we have a router cisco 3825.
the router has 256 mb of memory, but it is not using all of it because of dead process which is called "usb_startup" this dead process takes something like 60mb of the router memory. the reload command doesnt solve the problem.
how can we solve the probelm?
thank you
royalblues Wed, 04/25/2007 - 07:31
  • Green, 3000 points or more
Are you running short of memory? Has there been any problems on the network because of this?
I am not aware of any procedures which should stop this.
Though not a good suggestion, degrading the IOS which does not support the USB tokens might helphelp
Narayan
