SmartPort Configs missing
Apr 25th, 2007
Hi. Where can I find the macro's for the smartport's in a 3750? When I do a "show parser macro", I can see the macro but when I do a "show run", its not in the config.
Please help.
Thanks.
sbilgi Wed, 05/02/2007 - 05:24
  • Silver, 250 points or more
You can use the macro trace macro-name interface configuration command to show what macros are running on an interface or to debug the macro to determine any syntax or configuration errors. If a command fails when you apply a macro, either due to a syntax error or a to configuration error, the macro continues to apply the remaining commands to the interface. Refer URL
http://cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00801cdea8.html#55185
