Tracking the ATM PVC
Apr 25th, 2007
We are trying to identify a method where the ATM sub-interface shows line protocol UP but the ip reachability to the other side of the PVC is not there due to some issues in the ATM backbone.
Can we would be able to use the track 1 interface ip routing would help us . If so ,when it identifies the ip reachability on the PVC is done,will it log into the router or can it send to the management station. We are trying to deploy the same in 7600 switches running 12.2(18)SXF4.
Anantha Subramanian Natarajan
Overall Rating: 3 (1 ratings)
thomas.chen Wed, 05/02/2007 - 05:25
Use the command logging event atm pvc state to enable the logging of PVC.
