CM, DC, RME - Router are missing after tomcat restart
Apr 25th, 2007
After restarting Tomcat (because we have a web server issue ...) all the routers cannot be seen either on common services, RME or Device Center ...any idea ...???
lms 2.6 windows version
split mode : server one CM,DC and RME; server two IPM, DFM
Joe Clarke Wed, 04/25/2007 - 10:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Since you said you're integrated with ACS, there is most likely an integration issue. Check the Common Services > Device and Credentials > Reports > Devices not in ACS report, and see if they're being listed there.
