How many 3650 can i connect together
Apr 25th, 2007
Cisco Catalyst 3560 use SFP Interconnect Cable. How many switches do cisco recommend i can dasiy chain together?
sachinraja Thu, 04/26/2007 - 03:49
If you want to cluster, you can have 16 switches... refer to the URL below
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00801347f8.shtml#import
If you want to do non-cluster with daisy chain, it is 9 switches.. refer to the URL below
http://www.cisco.com/en/US/partner/products/hw/modules/ps5455/prod_release_note09186a00800d9ca9.html#wp8535
Hope this helps.. let us know if you need anything else... rate replies if found useful..
Raj
network_team Mon, 04/30/2007 - 01:19
Thanks for the information but the documents do not state any information about 3560. Can i dasiy chain 3 together
