NetPro forum support
Answered Question
Apr 25th, 2007
  • Gold, 750 points or more
Dear All,
Anybody know the contact address for Cisco NetPro forum!! i need to report vert strange issue happened in my profile, so if anybody know such contact please help.
Best Regards,
Mounir Mohamed
Correct Answer by ankbhasi about 10 years 1 month ago
Hey Mounir,
I don't want to make any wrong presumptions :). You never know what happened at the background so lets wait for the updates from moderator.
Ankur
Hi Mounir,
Great to know things got sorted out for you. I can feel the excitment in your post. Keep replying to this great forum with your valuable inputs and knowledge.
Ankur
Correct Answer by ankbhasi about 10 years 2 months ago
Hi Mounir,
As updated my Harold you may update your points and star related issues on Netpro feedback link and someone form netpro admin team will look into your problem.
Ankur
Overall Rating: 4.3 (10 ratings)
mounir.mohamed Thu, 04/26/2007 - 07:01
Dear hritter,
Thanks, i have very strange problem, currently i have bronze star with 112 points, but it's now shown with my username anymore, in the same time when i login via my account and check my profile i found everything normal (Points and star / recent posts is there) but if i post replay to any guest and if he click on my username it's will shown a very old posts only and no points at all, but if he check the top NetPro he will find my points and posts!!!!
Do you have any clarification for that.
Best Regards,
Mounir Mohamed
Correct Answer
ankbhasi Thu, 04/26/2007 - 07:21
  • Cisco Employee,
Hi Mounir,
Ankur
mounir.mohamed Tue, 05/08/2007 - 23:55
Dear ankbhas,
My problem has been solved 2 days ago, i have received confirmation from NetPro Moderator that they trying to isolate my issue and Now my stars become visable, also it's seems that they migrate all my accounts because my rate points get up:) Thanks NetPro Moderator
Best Regards,
Mounir Mohamed
paolo bevilacqua Thu, 04/26/2007 - 10:14
  • Hall of Fame,
    Founding Member
it seems to me that you have two accounts, one "Mounir.Mohamed" and one "mounir.mohamed" all lowercase, from that the confusion.
mounir.mohamed Thu, 04/26/2007 - 10:46
Yes that's the case, but there is a relation between both accounts because when i login by mounir.mohamed and post any replay it's post it with Mounir.Mohamed :) very strange case.
mounir.mohamed Thu, 04/26/2007 - 11:20
i swear there is a relation between the tow accounts because when i changed the password of mounir.mohamed, it's automaticlly changed for Mounir.Mohamed!!!!
paolo bevilacqua Thu, 04/26/2007 - 11:44
  • Hall of Fame,
    Founding Member
In any case, thank you (not) for rating low a mere observation meant to help. I hope you will encounter similar appreciation in your efforts.
mounir.mohamed Sat, 04/28/2007 - 23:08
Dear p.bevilacqua,
Actually I?m not who rate your replay  also I will never rate anyone with NOT helpful rating points (1) why I should rate something not helpful for me, Sure everybody is thanked for any replay because at least he waste 30 seconds to replay in NetPro posts which is a great effort from my point of view, but if I do so I will rate everyone even if the replay not helpful, So it?s a big difference between the appreciation of professionals efforts (Like you) and the helpful posts which may come from inexperience person But he got it because he faced the same problem before, finally NEVER Assume  because am not who rate your replay with 1, but rally I?m appreciate your effort so much.
Best Regards,
Mounir Mohamed
paolo bevilacqua Sun, 04/29/2007 - 03:09
  • Hall of Fame,
    Founding Member
Hi Mounir,
You are right -- one should never assume. But, I had found strange to be rated low for a casual and non-technical post with nobody involved but you. Anyway, does not matter at all.
Good luck!
mounir.mohamed Sun, 04/29/2007 - 03:20
Sure doesn't matter at all, you welcome man :)
I'm just rate for professional Attudie, the life not only technical :)
Best Regards,
Mounir Mohamed
mounir.mohamed Wed, 05/09/2007 - 00:12
Dear hritter,
Special thanks for you about your direct support, i can not rate you again the rate window closed it's seems that i can not rate more than once:)
Best Regards,
Mounir Mohamed
Correct Answer
ankbhasi Wed, 05/09/2007 - 00:30
  • Cisco Employee,
Hi Mounir,
Ankur
mounir.mohamed Wed, 05/09/2007 - 00:36
Dear ankbhasi,
Yes :) Thanks again
Best Regards,
Mounir Mohamed
mounir.mohamed Thu, 05/10/2007 - 03:31
Dear All,
I have a veryyy strange problem, MY rating jumps up bu just pressing refresh on my Internet Explorer in an abnormal behavior, i was 277 point's today, Then and after only one hour i found my self 320 point, then and after only 10 minutes i found my points 390 and so on, i can not beleive i got all such points on a short period with few replies.
Here is a log:
Name Points Average
Rating
mounir.mohamed 320 4.6 6
My points after 5 minutes:
Name Points Average
Rating
mounir.mohamed 430 4.6 6
Kindly advice in order to preserve the value of rating.
Best Regards,
Mounir Mohamed
ankbhasi Thu, 05/10/2007 - 03:42
  • Cisco Employee,
Hi Mounir,
Use the same feedback link and update the issue there and Netpro moderator will take care of the issue.
Ankur
mounir.mohamed Thu, 05/10/2007 - 03:48
Dear ankbhasi,
Done, but i get crazy how that happen, YOU can not imagen how the rate was growth, it get up 100 point with only one refresh press.
i was 320 and just few minutes i got 430, in the same time the number of votes was 127, durring such few minutes my votes become 149, so if we say there is 22 user rate my with the maximum rate value "5" i will never get this rate, also it's not logic all the users rate me in the same seconds, also the number solved issue growth,So What happen!!
Do you think they migrate my duplicate profile Twice!!
Best Regards,
Mounir Mohamed
Correct Answer
ankbhasi Thu, 05/10/2007 - 03:56
  • Cisco Employee,
Hey Mounir,
Ankur
mounir.mohamed Thu, 05/10/2007 - 04:09
Dear Ankur,
i'm waiting but i'm worry because tomorrow i may find my self having a points more than the moderator, and this time i will lost my credibility :(
Best Regards,
Mounir Mohamed
paolo bevilacqua Thu, 05/10/2007 - 04:30
  • Hall of Fame,
    Founding Member
But is easy to get more points than moderators, as they have none :)
The one thing would decrease your credibility, is if you was to say you hacked the site to get the points :)
mounir.mohamed Thu, 05/10/2007 - 04:40
Sure no, because i can not do that :) and if the points keep increased i will change my username and start from 0 it's Honor more than get points from null0, i got 110 point in 2 minute so it's a blackhole because no human can do that it's a magic:)
mounir.mohamed Thu, 05/10/2007 - 04:30
Yes it's a profile issue, i got the below message while i close the internet explorer and try to login again
Networking Professionals Connection
NetPro
* Profile
************** ERROR: Missing ending tag ************** ERROR: Missing ending tag ************** ERROR: Missing ending tag ************** ERROR: Missing ending tag ************** ERROR: Missing ending tag ************** ERROR: Missing ending tag
paolo bevilacqua Thu, 05/10/2007 - 05:01
  • Hall of Fame,
    Founding Member
Oh, the follies of being part of a star system :)
mounir.mohamed Thu, 05/10/2007 - 05:06
No code NO bugs, the bugs will be there as soon as there is a code :)
mounir.mohamed Fri, 05/11/2007 - 10:09
I had received an email from Netpro Admin today, which declear that there is 3 guys rate me with over 100 point in one day and to be fair enough i had aggred with him to remove such points if not legal.
Thanks again Netpro Moderator :)
Best Regards,
Mounir Mohamed
