asa 5505 - blocking url without websense or N2H2
Apr 25th, 2007
Hi !
I just have a couple of url to block, so I don't really want to implement a server like websense or N2H2 to manage the web content I want to block. Is there a way in the ASA-5505 to deny access to certain web pages with the url of the page ?
sachinraja Thu, 04/26/2007 - 04:05
hello gprever,
I really dont think this is possible.. one way is to use ACLs to block IPs of the particular URL's .. or to use an external proxy server, which can do this.. most of the proxy servers now do basic URL filtering..
Hope this helps.. all the best..
gprever71 Fri, 04/27/2007 - 02:57
I was thinking about a string value as a regular expression and then reject it in an inspect class map; but I haven't fiddled around with it yet, so I don't quiet understand how it works really. Any body who would think it is achievable that way ?
oabduo983 Fri, 04/27/2007 - 03:30
It is acheivable through Regex... I'm still looking for a solution... I was working on it last night, but could not get it to work... i would appreciate if somebody can post some lines on this...
The following is my work trying to block access to please advise if you know how to fix this issue:
PIX Version 7.2(2)
regex test1 ""
regex test2 ""
regex test3 ""
route outside 1
class-map type regex match-any httpkill
match regex test1
match regex test2
match regex test3
class-map inspection_default
match default-inspection-traffic
class-map type inspect http match-all httpkill1
match request uri regex class httpkill
policy-map type inspect http httpkill1
class httpkill1
drop-connection log
policy-map global_policy
class inspection_default
service-policy global_policy global
