MAC Address router Module
Apr 25th, 2007
I have 2800 series router.
It has ethernet interface . Can I know the MAC address of the interface ?? Like the MAC address of the PC LAN Card.
biplob
Overall Rating: 3 (1 ratings)
ankbhasi Wed, 04/25/2007 - 22:32
  • Cisco Employee,
Hi Biplob,
Is it the default ethernet interface you are talking about? If yes you can issue "sh interafce " to get the mac address for that particular interface.
Ankur
iqbalkhan Wed, 04/25/2007 - 22:54
Ok. If the module has two FE port then same MAC address for the two ethernet interface or
MAC address for only module not interface ?
thanks
Biplob
ankbhasi Wed, 04/25/2007 - 22:58
  • Cisco Employee,
Hi Biplob,
Mac address will be for each interface. So if there are 2 interface "sh int & sh int " will give you the mac address of both the interface.
Ankur
*Pls rate all helpfull post
