Locally Generated Traffic QoS Values
Apr 26th, 2007
How can you change the QoS/DSCP values of locally generated router traffic?
A router connected to an MPLS provider needs to mark its own management traffic to fit the providers QoS policies. So I need to mark telnet/ssh and similar locally generated traffic (which wont pass in via a service-policy) as AF32 instead of the default CS6.
Overall Rating: 4.5 (2 ratings)
mohammedmahmoud Thu, 04/26/2007 - 01:09
Hi there,
you can use a local policy to control the locally generated traffic:
ip local policy route-map CM
route-map CM permit 10
match ip address 101
set ip precedence
and the access-list 101, should define your desired traffic.
HTH, please rate if it does help,
Mohammed Mahmoud.
b.henshaw Sat, 04/28/2007 - 02:13
In addition to Mohammed's clear and succinct response, if you need to set a specific DSCP value you can use "set ip dscp xx" in the route-map.
On platforms where "set ip dscp" is not supported you can use a combination of "set ip precedence" and "set ip tos" to achieve the same outcome.
Brad
ratings appeciated
