Convertion from Lightweight to Autonomous access points
Apr 26th, 2007
Is it possible to convert AIR-LAP1121G-E-K9 Lightweight access point to autonomous access point.
sajism220 Thu, 04/26/2007 - 04:13
Hi tm,
You can convert AIR-LAP1121G-K-E9 to autonamus access point,pls do follow the procedur
Follow these steps to revert from LWAPP mode to autonomous mode by loading a Cisco IOS release using a TFTP server:
Step 1 The static IP address of the PC on which your TFTP server software runs should be between and
Step 2 Make sure that the PC contains the access point image file (such as c1200-k9w7-tar.122-15.JA.tar for a 1200 series access point) in the TFTP server folder and that the TFTP server is activated.
Step 3 Rename the access point image file in the TFTP server folder to c1200-k9w7-tar.default for a 1200 series access point, c1130-k9w7-tar.default for an 1130 series access point, and c1240-k9w7-tar.default for a 1240 series access point.
Step 4
Connect the PC to the access point using a Category 5 (CAT5) Ethernet cable.
Step 5
Disconnect power from the access point.
Step 6
Press and hold MODE while you reconnect power to the access point.
Step 7
Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds) and then release.
Step 8
Wait until the access point reboots, as indicated by all LEDs turning green followed by the Status LED blinking green.
Step 9
After the access point reboots, reconfigure it using the GUI or the CLI.
Saji k.s
Trending Topics - Security & Network
