pix 515E can't use the Fe0 and Fe1
Apr 26th, 2007
Dear sirs,
i have cisco pix 515E with three interfaces Fastethernet0, Fastethernet1 and built-in in the pix and Fastethernet2 which is module.
i upgrade it to ver. 7.0
when i connect the firewall the fe0 and Fe1 is bring up and the light is ok but i can ping them or use them , but the interface Fe2 which module is ok i can ping it or use it.
Is it hardware failure or what.
abdo2000a Thu, 04/26/2007 - 06:27
sorry,
i mean i can not ping or use the Fe0 or Fe1, but i can use and ping the Fe2.
i use simple configuration on the pix ( inside , outside and Dmz).
