QOS on Frame Relay link
Answered Question
Apr 26th, 2007
Hi,I have a 512k HUB access-pipe and 6 pvc's configured on this pipe. WFQ is enabled by default on this WAN interface and no other queueing is used. When a packet arrives to be transmitted out to all 6 pvc's, I would expect a certain amount of serialisation/Propogation delay. My question is does the cisco router use the actual access-speed of the main interface ie the CIR/speed of the spoke sites are not involved.
Mary
Correct Answer by jwdoherty about 9 years 5 months ago
By default, believe the hub site will transmit as quickly as possible.
Highly recommend defining each PVC as its own subinterface with traffic shaping that conforms to the far side's bandwidth.
BTW: at least in North America, the CIR usually isn't the limiting factor, the actually port speed is. Of course, when you exceed CIR the vendor could drop all traffic that's above it. If you define shaping, you could shape to CIR, port speed, or anything in between.
Overall Rating: 5 (1 ratings)
Correct Answer
jwdoherty Fri, 07/27/2007 - 10:33
