VRF selction
Answered Question
Apr 26th, 2007
Is VRF selection feature been integrated in 7600 platform based IOS trains..If so, can you please let know .
Anantha Subramanian Natarajan
Correct Answer by swaroop.potdar about 10 years 1 month ago
VRF Selection with PBR is an enhancement over for the the previous source based selection. As you have multiple selection criteria available with the policy map and you can set the VRF with your match criteria.
HTH-Cheers,
Swaroop
Overall Rating: 4.8 (3 ratings)
Correct Answer
swaroop.potdar Thu, 04/26/2007 - 12:02
  • Blue, 1500 points or more
HTH-Cheers,
Swaroop
anasubra_2 Thu, 04/26/2007 - 13:33
oh is it...thanks ...i think both may helps us if we have the correct IOS on the network
