802.1Q support on Cisco 871
Apr 26th, 2007
Hi:
Reviewing Cisco 871 info, I don?t see 802.1Q support over "WAN port". It supports 802.1Q over the four LAN ports, but it says nothing about WAN port.
Thanks.
ankbhasi Thu, 04/26/2007 - 10:08
  • Cisco Employee,
Hi Friend,
By WAN port you mean serial port? dot1q is lan protocol and not a wan protocol.
What is your requirement?
Ankur
paolo bevilacqua Thu, 04/26/2007 - 12:06
  • Hall of Fame,
    Founding Member
Have you ever seen an 871? The ethernet port to connect the ISP broadband modem is labeled WAN, coherently with the industry standard for this class of device.
The question is valid. Unfortunately I don't have an 871 to try that.
