Cisco 7960 to SIP
Apr 26th, 2007
Hi All!
I've a problem with my new Cisco 7960 Phone.
I want to configure my 7960 for using it with SIP. But default the firmware is based on Call Manager. So, I tried to get new firmware into the phone, but I can't get it working.
I've set up a TFTP server. In the root there are some files:
OS79XX.TXT
P0S3-08-2-00.loads
P0S3-08-2-00.sb2
P003-08-200.bin
P003-08-2-00.sbn
SEP001A2FA6F9D2.cnf.xml
SIP001A2FA6F9D2.cnf
SIPDefault.cnf
XMLDefault.cnf.xml
I get the P0*.* files from the Cisco site. That's the SIP 8.2 firmware.
When I turn my phone on, I see the following in my phone screen:
Configuring VLAN
Configuring IP
Configuring CM List
Configuring IP
Configuring CM List
Configuring IP
Configuring CM List
Configuring IP
Configuring CM List
In my TFTP server logs I see this:
26-4-2007 19:16 :Sent OS79XX.TXT to CISCO-7960.lan (192.168.1.64), 13 bytes
26-4-2007 19:16 :Sending SEP001A2FA6F9D2.cnf.xml to (192.168.1.64)
26-4-2007 19:16 :Sent SEP001A2FA6F9D2.cnf.xml to CISCO-7960.lan (192.168.1.64), 613 bytes
26-4-2007 19:16 :Sending OS79XX.TXT to (192.168.1.64)
I don't understand anything about this phone, but I want only call with that phone with my VOIP line over SIP.
Please help me to configure my phone!
Thanks a lot.
Danido.
Paolo Bevilacqua Thu, 04/26/2007 - 10:24
Hi Dadido,
Unfortunately the cisco phones are not particularity easy to use with a non-cisco callmanager. This said, luckily there is a lot of info on the subject on voip-info.org, just search cisco 7960.
In your case, the first step is to configure the "load" to change the firmware to SIP.
Note that Cisco also released a version of SIP software for "non-callmanager" application, currently 8.6(0). Strangely enough, it has not been reviewed on voip-info.org.
Good luck!
Hope this helps, if so please rate post using the scrollbox below!
Klavertje19 Thu, 04/26/2007 - 11:08
Thank you for your fast reply!
I've already downloaded the SIP software for non-callmanager. The version I've downloaded is 8.3
I will search on voip-info.org. I hope I can find a way to use my 7960. If you've more tips, please tell me.
Danido.
