Joe Clarke Thu, 04/26/2007 - 13:12
Specifically what traps would you not like sent out from the switch?
sundar.palaniappan Thu, 04/26/2007 - 13:42
I would say all events pertaining to the IDSM. But, if that's not possible then we don't want the switch to send out link status traps for the IDSM internal(backplane) interface(s).
Joe Clarke Thu, 04/26/2007 - 15:08
In this case, what you can disable specific to the IDSM will be very limited. If there is an interface for the IDSM that shows up in the switch config, you can add:
no snmp trap link-status
Under that interface. Any other traps (e.g. module up/down traps) can be disabled, but you will then lose them for all modules.
sundar.palaniappan Thu, 04/26/2007 - 15:39
That's what I thought. I just wanted to get a second opinion to confirm my conclusion.
The internal interfaces do not show up in the switch config to disable snmp trap link status. Moreover, we won't be able to disable module up/down traps for the other cards in the switch.
Sundar
