04-26-2007 03:03 PM - edited 03-14-2019 09:11 PM
I have a customer that has a 6 line phone in CME. If they wanted all 6 lines to be able to takes calls for the same number so that they do miss a call and can put a bunch of callers on hold, what would that look like from a configuration example?
Would they just forward to the next line when the dual-line has two calls in use on the first button or can they use a no huntstop type configuration?
04-26-2007 04:15 PM
pat see below.
This is one way you could do it. voice-port 0/1/0 is connected to your incoming PSTN number. When it gets a call it automatically forward it to DN 1000. DN 1 (1000), dn 2, dn3 and so on are defined as line buttons on the six line phone. First call comes into 1000. 2nd call comes into 1002 if 1000 is busy and so on. The other way to do it is to use the ephone-hunt series of commands with a pilot number.
voice-port 0/1/0
timeouts call-disconnect 5
timeouts wait-release 5
timing sup-disconnect 650
connection plar 1000
description ***Incoming from 777-4343***
caller-id enable
ephone 34
username "newuser" password xxx
mac-address 0015.62C3.90E8
type 7960 addon 1 7914 2 7914
button 1:34 2f1 3f2 4f3 5f4 6f5
ephone-dn 1 dual-line
number 1000
label Incoming 1
call-forward busy 1002
call-forward noan 1002 timeout 10
huntstop channel
ephone-dn 2 dual-line
number 1002
label Incoming 2
call-forward busy 1003
call-forward noan 1003 timeout 10
huntstop channel
ephone-dn 3 dual-line
number 1003
label Incoming 3
call-forward busy 1004
call-forward noan 1004 timeout 10
huntstop channel
ephone-dn 4 dual-line
number 1004
label Incoming 4
call-forward busy 1005
call-forward noan 1005 timeout 10
huntstop channel
ephone-dn 5 dual-line
number 1005
label Incoming 5
call-forward busy 1000
call-forward noan 1000 timeout 10
huntstop channel
04-26-2007 07:29 PM
Hi Patrick
Another way to do it is to create 6 dn's with the same number, using huntstop channel and no huntstop incoming calls will hunt from dn to dn.
example
voice-port 0/1/0
caller-id enable
number 1000
huntstop channel
no huntstop
number 1000
huntstop channel
no huntstop
number 1000
huntstop channel
no huntstop
number 1000
huntstop channel
no huntstop
number 1000
huntstop channel
no huntstop
ephone-dn 6 dual-line
number 1000
huntstop channel
ephone 1
mac-address xxx.xxx.xxx
type xxxx
button 1:1 2:2 3:3 4:4 5:5 6:6
or
ephone 1
type xxxx
button 1o1,2,3,4,5,6
First ephone method uses all six lines, second method uses one line with overlays.
Hope this helps
