CCM 4.x and MCS-7815I2 and Windows 2000 OS drive mirroring??
Apr 26th, 2007
With CCM 4.x running on an MCS-7815I2 (IBM) is anyone out there installing a 2nd Hard Drive in these servers and then using Windows 2000 OS software mirroring for drive fault tolerance?? Is it supported by Cisco?? Also it appears that although these servers have SATA RAID built into the BIOS that Cisco does not want you to use this feature on Call Manager Servers??
Thanks in advance,
