L2VPN with backup peer
Hi, i need make a fully redundancy configuration for two CE?s.
this CE?s are only capable of run static routing between them.
here is the option that i have, and i need your confirmation over this solution.
this solution must be tolerant to hardware failure
(complete box or only one module) and software.
thanks for your collaboration :)
CEs are non-cisco devices, but the concept is the same.
the questions are:
1- L2VPN configured in the SVI works with STP?
2- if it works, in normal conditions the STP state of the ports will be,
CE1 G1/1-2 DP->FW
PE1 G1/1 RP->FW
 G1/2 DP->FW
PE2 G1/1 RP->FW
 G1/2 NDP->BLK
PE3 G1/1 DP->FW
 G1/2 DP->FW
PE4 G1/1 DP->FW
G1/2 NDP->BLK
CE2 G1/1 RP->FW
G1/2 NDP->BLK
what is the RP of PE3 and PE4??
3- finally, if this config dont work, how can accomplish this?
CE1
spann vlan 10 priority 4096
vlan 10
int vlan 10
ip add 10.0.10.1 255.255.255.0
int giga1/1
description to PE1
sw mo acc
sw acc vla 10
int giga1/2
description to PE2
sw mo acc
sw acc vlan 10
CE2
spann vlan 10 priority 24576
vlan 10
int vlan 10
ip add 10.0.10.2 255.255.255.0
int giga1/1
description to PE3
sw mo acc
sw acc vla 10
int giga1/2
description to PE4
sw mo acc
sw acc vlan 10
PE1
spann vlan 10 priority 8192
vlan 10
int lo0
ip add 10.0.0.1 255.255.255.255
int vlan 10
no ip add
xconnect 10.0.0.3 13 encap mpls
backup peer 10.0.0.4 14 encap mpls
int giga1/1
description to CE1
sw mo acc
sw acc vla 10
int giga1/2
description to PE2
sw mo acc
sw acc vlan 10
PE2
spann vlan 10 priority 12288
vlan 10
int lo0
ip add 10.0.0.2 255.255.255.255
int vlan 10
no ip add
xconnect 10.0.0.4 24 encap mpls
backup peer 10.0.0.3 23 encap mpls
int giga1/1
description to CE1
sw mo acc
sw acc vla 10
int giga1/2
description to PE1
sw mo acc
sw acc vlan 10
PE3
spann vlan 10 priority 16384
vlan 10
int lo0
ip add 10.0.0.3 255.255.255.255
int vlan 10
no ip add
xconnect 10.0.0.1 13 encap mpls
backup peer 10.0.0.2 23 encap mpls
int giga1/1
description to CE2
sw mo acc
sw acc vla 10
int giga1/2
description to PE4
sw mo acc
sw acc vlan 10
PE4
vlan 10
int lo0
ip add 10.0.0.4 255.255.255.255
int vlan 10
no ip add
xconnect 10.0.0.2 24 encap mpls
backup peer 10.0.0.1 14 encap mpls
int giga1/1
description to CE2
sw mo acc
sw acc vla 10
int giga1/2
description to PE3
sw mo acc
sw acc vlan 10
swaroop.potdar Thu, 04/26/2007 - 20:03
  • Blue, 1500 points or more
What would happen here is the same when you connect 2 plain switches
back to back with two connections using a access port!!!.
TO avoid that, and rectify you may try things as below.
1) There wont be any blocking state as all your ports are access ports.
Spanning tree is disabled on access ports.
2) You can remove the access connection between PE1-P42 and PE3-PE4.
Not advisible to extend L2 rings above the NPE devices, it should
be below the NPE. If you want to configure that connection then use
a trunk and only pass SP VLANS only and no customer VLANS at all.
3) With the linear setup you have you can omit the backup peer statement.
3) Configure a trunk with the CE's.
4) Carry all the vlans/vlan received from the CE on the trunk using QinQ withing the SP vlan.
5) With the above points in place you will have 2 trunk connections between the 2 CE's switches forming a ring. And then you can run STP to break the ring/loop.
HTH-Cheers,
Swaroop
