Offnet to Offnet Transfer
Apr 26th, 2007
Hi All,
I have got a problem on CCM4.2 where the Offnet to Offnet transfer wont't work. I have checked the service parameter to make sure it is allowed. External party A calls in. I press transfer then dial another external party B. I can announce the call to external party B. As soon as i press transfer to connect the 2 partys. Both calls get disconnected. Is it possible that there is something on the gateway that has to be done to allow this. It is happening on 2 differtent sites. 1 is PRI and the other BRI.
thisisshanky Thu, 04/26/2007 - 18:44
  • Purple, 4500 points or more
Can you get a debug isdn q931 output of the call flow ?
csco10968068 Thu, 04/26/2007 - 20:01
Hi Thisisshanky,
Following is the bebug.
*Apr 27 13:47:11.212: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x00CC
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18388
Preferred, Channel 8
Progress Ind i = 0x8083 - Origination address is non-ISDN
Calling Party Number i = 0x2181, '738401218'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '30104203'
Plan:ISDN, Type:Subscriber(local)
High Layer Compat i = 0x9181
*Apr 27 13:47:11.228: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x80CC
Channel ID i = 0xA98388
Exclusive, Channel 8
xtreamdemortr1#
*Apr 27 13:47:11.400: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x80CC
*Apr 27 13:47:12.156: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x80CC
*Apr 27 13:47:12.192: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x00CC
xtreamdemortr1#
*Apr 27 13:47:12.192: %ISDN-6-CONNECT: Interface Serial0/0/0:7 is now connected to 738401218 N/A
xtreamdemortr1#
*Apr 27 13:48:18.924: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 3103
*Apr 27 13:48:18.928: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num 38401285
*Apr 27 13:48:18.928: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x023A
Standard = CCITT
Channel ID i = 0xA9838A
Exclusive, Channel 10
Calling Party Number i = 0x0081, '3103'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '38401285'
xtreamdemortr1#
*Apr 27 13:48:19.116: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x823A
*Apr 27 13:48:19.480: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x823A
Progress Ind i = 0x8082 - Destination address is non-ISDN
Progress Ind i = 0x8488 - In-band info or appropriate now available
xtreamdemortr1#
*Apr 27 13:48:23.384: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x823A
Date/Time i = 0x07041B0D38
*Apr 27 13:48:23.388: %ISDN-6-CONNECT: Interface Serial0/0/0:9 is now connected to 38401285 N/A
xtreamdemortr1#
*Apr 27 13:48:23.388: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x023A
xtreamdemortr1#
*Apr 27 13:48:32.784: %ISDN-6-DISCONNECT: Interface Serial0/0/0:9 disconnected from 38401285 , call lasted 9 seconds
*Apr 27 13:48:32.784: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x023A
Cause i = 0x80C1 - Bearer capability not implemented
*Apr 27 13:48:32.792: %ISDN-6-DISCONNECT: Interface Serial0/0/0:7 disconnected from 738401218 , call lasted 80 seconds
xtreamdemortr1#
*Apr 27 13:48:32.792: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x80CC
*Apr 27 13:48:32.856: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x823A
*Apr 27 13:48:32.856: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x023A
*Apr 27 13:48:32.896: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x00CC
*Apr 27 13:48:32.896: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x80CC
xtreamdemortr1#
xtreamdemortr1#
mparekh Wed, 11/07/2007 - 09:37
  • Bronze, 100 points or more
Any updates to this i am getting similar message in UK
