very short trunk
Apr 26th, 2007
hi guys...what possible trunk can be connected between pbx and cisco router in short cable (5 meter)? is it E1/T1... ops.. by the way do we only need plain e1/t1 without kind of signal such pri? please help... beside that how dialpeer would map to this trunk? please teach me. tx very very much...
Paolo Bevilacqua Fri, 04/27/2007 - 02:20
5m is not a problem. Please use correctly twisted cable as per pinout.
If possible at all, configure the PBX as PRI. If absolutely not possibile, tell us that choices do you have, what do you want to do, and we can suggest something.
jemekeren Fri, 04/27/2007 - 21:16
basically i want to replace fxo cable from router to pbax port which are 20 cable/line with single trunk and i still wonder how another additional setting and dialpeer config that need modified in place of existing dialpeer. would you please helps? tx :)
