vpn tunneling issue during migration 6.3.4 to7.1.2
Apr 26th, 2007
I'm Having problems with RA vpn users authenticating with Vasco tokens on my new ASA 5510 platform. I,m migrating from PIX 6.3.4 to the ASA. In my PIX configuration I used the command:
crypto map outside_map client token authentication ABCXYZ to let vpn client users authenticate with a Vasco token on login.I cannot apply this command on my ASA. Asa says:
The 'crypto map <map_name> client authentication' command syntax has been deprecated, and will be applied to the existing tunnel-groups.
When I check my config afterwards, I do not see any changes in the config off my tunnel-groups.
Vasco authentication fails.
Is there a way to apply this to my ASA config or is there a way to work around it?
oabduo983 Fri, 04/27/2007 - 03:33
  • Bronze, 100 points or more
It should be there but converted to the new format under the tunnel group (different command for the same function)
